I clecoed the W-703 to the right wing and added clecoes every four holes. I final drilled to #40 and then used my soldering iron to remove the vinyl from the rivet line so that I can dimple the skins.
Once I completed that, I move over to the left wing in the stand and decided to run the conduit through the ribs to support the wire run. What a pain that was. I actually bled on that one after I ripped my finger down the rib. Lots of extra conduit at the fuselage end and about a foot left at the wing tip end.
I have to finish the support bracket for the right wing post. Once that's done tomorrow, I'll move the right wing into the stand and get a little bit of space back.
I removed the top skins and flipped the right wing and clecoed on the bottom skins. Waiting for my Aircraft Spruce order to arrive...some extra clecos are on the way.
